Hi guys!
I'm a Norwegian XS user and have just received the update for firmware .73.
When Im starting updating, I get a error:
"Error installing
Can not install or start the components for updating the phone software"
/ Norwegian:
"Feil under installering
Kan ikke installere eller starte komponenter for oppdatering av telefonprogramvare."
I press close and it says that updating failed.
Whats wrong?! Debugging on phone is activated and internal storage is connected.
Please help! I really want to update my phone now!
Thanks!
you can use SUS
Update Service (SUS)
Please try these steps to resolve the situation:
1. Close PC Companion.
2. Install java from http://www.java.com/
3. Start PC Companion again and try to do the SW Update of the phone.
you can use SUS
Thanks for answers.
Tried installing Java and then start PC Companion and software update, but same error.
So I installed SUS and finally able to update to latest firmware without any problems!
Thanks to both.
Anytime
I'm happy to know that you could finally update it.
