annulla
Cerca invece
Intendevi dire:
Error when rooting Xperia V with Flashtool
RISOLTO
austin27
Visitatore
hi
i am using xperia v lt25i
and i couldnt able to flash any ftf files and gettind errors and
shows device disconnected
plz help me anyone
1 SOLUZIONE ACCETTATA
Soluzioni accettate
Thommo
Genius
You can either use another Pc running XP, Vista or Win 7 but 32bit versions only as the Flashdriver is incompatible but I also believe that Microsoft has a Virtual mode on Win 8 which I think M/S has a free XP operating system to install to it but I can't be sure - I'll look it up[ and post back later
Visualizza soluzione nel messaggio originale
32 RISPOSTE 32
Thommo
Genius
Sounds like either your driver isn't installed or you are running Windows 7 or 8 64bit
austin27
Visitatore
yes you are absolutiy right
i am using 64bit win 8
any suggestions so that i can flash my v(lt25i)
Thommo
Genius
Thommo
Genius
So you can run a program called Hyper V found here or it may already be installed but needs turning on - This then allows you to install XP etc to that virtual Pc, There is a downloadable XP from M/S but it says it's for Win7 only however there are forums which members have said they have it working - File is here or if you have an XP install disc then you can use that just remeber to install it to your virtual Pc once done you should be able to use Fastboot and Flashtools for the use of Unlocking your Bootloader and Flashing Roms and or the stock .FTF files
austin27
Visitatore
ill download and try thanks for the help and hope i can flash it !!!!!!!
so is the win8 the reason that my v is not getting flashed ???
no phone problems
Thommo
Genius
It's the incompatibility due to your system been a 64bit so it's not your phone and your Pc is fine it's simply because it's 64bit
austin27
Visitatore
okay sir ill use another system and kepp u posted
and can u tellme how i can install clockworkmod recovery menu
Thommo
Genius
You need to be rooted 1st
Then you need to install Busybox from the Play store, Make sure on your phone you have usb debugging enabled and unknown sources ticked then download this file here extract the contents from the rar file to a folder then inside said folder run the file called cwm-install-en and follow the on screen instructions - If all goes well when you turn your phone on a blue LED will show in the top left corner when it appears simply press the volume down key or up key
austin27
Visitatore
i did as u directed
but it says error while excecuting adb?????
