Could not Export Data : unknow Error(Backup Contacts)
Hi All,
I have Xperia Arc S,Recetly i have updated Android from 2.3 to 4.0.3.
After upgrade,when i am trying to take backup of contact,it is failing with error:
It is Exporting till 62% and then its showing error with canceling the backup.
What could be the error?
Is it a known Bug?
Thanks,
Piyush
Nabeel
I think you may need to format your SD card first
backup important stuff from memory card to pc then format your sd card ( settings > storage > erase sd card )
Nabeel
