boot loop
viswajith
boot loop
I really need help my xperia t2 ultra dual freezes and restarts and goes on like this,i cant reset my phone or do anything with it.every time i turn on my phone this happends. My phone is currently running official lolipop.
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
7 REPLIES 7
_alexdon_
alexdon
viswajith
I see... I will try that..
viswajith
Do i have to be connected to the internet while i do this??
_alexdon_
Only your PC/laptop needs to be connected.
alexdon
viswajith
Thanks man worked just fine
_alexdon_
Awesome.
alexdon
LeeYW94
I did everything as instructed. But in the end there s a problem with pcc. It said there is no software available for your device. I tried to reinstalled the programme but same thing happened. Please help me
