Need help to unlock PIN for Xperia S
arsalan
Hello
I have set up a PIN lock for my Xperia S (LT26i). Now I can not remember exactly what I choose as PIN number. I forgot the PIN I previously set. Cannot use my phone since PIN is required to unlock screen. How can I unlock my phone from this point? I have tried to undate my phone and have updated it successfully but screen is still locked. Need help desperately regarding this matter. Thanks
Nabeel
Unfortunately you'll loose all data on your phone now
________________________________________________________________
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions
4 REPLIES 4
Nabeel
akshay2602
can  i use it for sony xperia L
its under wrranty period
you can use SUS on your Xperia L too
Jan71
Hi I've tried this method but I couldn't get into my phone.
I don't know what to do I can't remember the pin number so the phone is locked!
It's been a while since i used the phone cos I got a new one but I want to go back to this one I've tried all the combo's I always use but none of them work.
Is there any other way to reset the phone with the screen lock on??
I'm at my wits end.
 Thanks
