Battery problem xperia arc
After i've done a software restore with pc companion the batery don't charge with usb cable or with the battery charger... I don't know what to do... Just i Unplug the cable the phon shut down.....
19 REPLIES 19
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
Other ways to install the "Backup & Restore App"
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Manager
W251bGwsMSwxLDEsImNvbS5tYWdtYW1vYmlsZS5hcHAuYXBraW5zdGFsbGVyIl0.
open "Apk Manager" and voila select the apps that you wan't to install
another alternative to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
I try in a minute and i'll let you know about...
Ok I hope its a software issue, that way you can fix it with SEUS
I've done the restore.. but the battery doesn't charge... It's possible to use anothe way? like flash a firmware?
Xperia Arc LT18i/a 2.3.4  4.0.2.A.0.62
http://talk.sonyericsson.com/thread/29197
Also with flashtool nothing good.. the phone work properly but i can't charge the battery....
can you borrow the battery from someone or from a store where they sell the Arc, that way you'll know if the problem is the battery or something else
I'll try it....
I've buy another battery on ebay because in Italy and especially near my city is not easy to have sony ericcson parts.. I don't know why... I'm waiting for the battery in 2 days... I hope It will work... I've send an email also to the assistance but they haven't answered....
