Hi all,
since two days there is a new problem with my Xperia SP (still on 4.1), which I use since 3 months.
Audio is not working sometimes. It started when I could not hear anything during calls.
When I switch on the speaker , it works. But it is annoying since others can hear what my partner is speaking. And it is too loud for my ear.
Then I recognized that other sounds are not working, too:
Others are working, like the alarm clock, notifications, rings.
Strange, isn't it?
I plan to upgrade to 4.3 but I need to backup everything first, which will take some time ...
smart connect is not installed on my phone. May be it has a different name in German ...
Anyway I solved the problem. The culprit is the app "FM radio". I used it this morning and everything was working again after I stopped it. I remembered that I stopped it last time just by unplugging the earphones when the speaker was switched on. This time I switched it off *before* unplugging the earphones.
Thanks for help
Have you tried settings-apps-all-smart connect,clear data and force stop?Then restart your phone.
Hi alexdon,
can you elaborate a bit? Do you mean to clear the cache of all apps and stop them?
Will try ...
Thanks
No,as Danial said,just for smart connect.It is an app that handles all the conection in/out the phone.
Thanks for help
