When the phone have notification. I see the different lights.
Which apps compatible and which colours?
Is xperia light app also support this?
It's hard to give you a list for all apps and which colors that they use since this is different from app to app. Also, this is something that the app itself needs to be programmed with to enable the LED.
If your LED flashing white you have a new message and if you are using Facebook, you will see different colors depending on the action from Facebook. For Facebook (if I'm not mistaken) you can see the color blue when you have a notification from Facebook such as friend request, tagged in a comment etc. And the color green will appear when you have a new message from Facebook.
Could you elaborate on Xperia Light?
Do not know if the others can. I already use xperia light app and the colour lights cannot set.
I'm not sure what you mean. Are you looking for an app that can manage the LED? I have not tried any of them by myself but perhaps "Light Manager" or "Light Flow Lite" can do this which can be found via Google Play.
Try different apps, as what you describe it's a compatibility issue, if you use whatsapp you can change the notification light color.
The notification light of my Sony Xperia Z3+ is constantly blinking and eat up the battery life... What should i do it stop it from blinking for no reason
, if there is a way to control frequency of led blinking at least with third party app? I still miss many notification because of short blink of notification LED.
So is this going anywhere ?
Because i surely can change color of notification light by using apps but the flashing duration.. it's just impossible i think
There's also forum that could not do it even with rooting or flashing some different ROM
https://forum.xda-developers.com/m4-aqua/help/led-notification-settings-missed-calls-t3166566
