Introducing the Sony SRS-LSR200 Wireless Handy TV Speaker
Peter_S.
Genius
5,643  Views
The SRS-LSR200 Wireless Handy TV Speaker brings your TV’s audio to where you are.
Whether you are watching TV alone, with friends and family, or even from another room, our brand-new wireless speaker ensures clear, crisp audio, so you won’t miss a thing. Compatible with all TVs*, the SRS-LSR200 features our innovative Voice Zoom technology to enhance spoken dialogue, 13 hours of battery power, easy set-up, big volume dial, universal remote functionality, a splash proof design, and more.
Watch the video:
*with headphone or optical output
13 Comments
corixa232
Explorer
Hi Peter - is it possible to use this speaker and also a soundbar?
Many thanks.
IamNic
Hello @corixa232,
yes, if you e.g. connect the soundbar via HDMI/ARC and the LSR200 via the optical output, you may use them both at the same time.
- Nic
The sound keeps breaking up even though the speaker is only about 1.5m away from the TV and base station.  Does anyone have a solution please?
IamNic
Hello @Colinstuart28,
best would be to create a seperate post for this instead of discussing this in the comments underneath the blog-article here.
In the manual I could find the following though:
The sound is interrupted.
-> Other radio waves are interfering. Keep as far away from wireless
devices or microwave ovens as possible. The sound may be
interrupted if a smartphone or tablet is nearby.
- Nic
Aliebanks
New
It’s all connected as per instructions. The base is charged but the speaker will not switch on. Is it faulty?
IamNic
Hello @Aliebanks,
kindly raise a new post to discuss this, as the announcement post of a product is not fit to do troubleshooting.
- Nic
profile.country.IE.title
MBFUHST
Explorer
RI just purchased the Sony SRS-LSR 200 from amazon.uk.    I am wanting to use it in the US.  What additional things will I need to make it compatible with power here?
IamNic
@MBFUHST,
please create a seperate post for such questions, as it will get buried here.
- Nic
corixa232
Explorer
@MBFUHST I think you’d just need a US / UK (if you’re in the UK) plug adaptor.
Anonymous
Hey there,
I don't think it's recommended to use a device from one region to another due to the difference in power specifications.
But yea, an adapter should make it work.
Hope it helps.
michaelcguntrip
New
Hi will I be able to use this Sony speaker and still be able to use my Bose soundbar or will it only work through my TV.
corixa232
Explorer
Hi @michaelcguntrip You should be able to use the soundbar and the wireless speaker at the same time. I use mine with a a JVC soundbar.
My soundbar is connected to the TV via HDMI, and the SRS LSR100 is connected to the TV via optical output.
If it's not working, have a dig around in the TV's audio output settings - look for 'dual output', or something similar. Try different output settings - one will almost certainly work. Especially given that both the TV and speaker are Sony.
Hope that helps.
Anonymous
That usually depends on your TV model, and whether it supports it or not.
