Xperia ZL didnt turn on with the power button. When tried to charge, not charging.
Tried (power+volume up) button for 10 secs, but didn't work. PC is not recognising the devise when connected ..!
I don't want to lose my data. Pl help..!
Connect the phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2-3 hours > then see if it turns on. If it doesn't repeat the process but with a different wall charger and cable.
@uliwooly
Thank u... I will try that But atleast the phone should vibrate na after holding the keys for 10 secs...? i don't see any sign of charging (red light) should I continue even then..?
