Z5 Premium battery draining while sleeping
read
I've been loging battery performance for a while, and I've noticed that there seems to be little variance between drain while in use and drain while sleeping.
Last night my battery dropped over 50% from 100% without any [major] on screen time. The phone was totally disconnected from any radio interfaces, and everything should have been sleeping.
I do have a white list to alow my smartwatch 3 to work while the phone's asleep, but these are things like Google services.
The battery stats for the period when the battery dropped shows;
Android system 10%,
Android OS 7%
Cell Standby 3%
Screen 3%
Phone Idle 2%
Media server 1%.
I don't really code that much anymore, but if this where a system I was debugging I'd be suspicious that Android Systems and Android OS are using such a big chunk of power while the system should be asleep and waiting to be activated by the only remaining interface, the cellar connection!
Any thoughts on this [Official or otherwise?]
Barry
read
Tell you what, lets just call this one closed shall we!
40 REPLIES 40
profile.country.PH.title
MarlonUk1
can you take a screen shot of the battery usage graph and screen?
read
read
read
Sorry if these are too big! I'm on my PC at the moment, and have uploaded them through Chrome from the Z5P that's tethered to the USB..
I've never had a phone loose so much power while I've been asleep [and it should have been asleep] with all the radio interfaces off! Like I said there is a white list to keep my watch running, which includes [Android Wear, Avast Anti theftl, Google App, Google Play Services, Google Service Framerwork]. Not sure if some of those would automatically be keept awake anyway, it was done largely through trial and error.
Android isn't a platform I've done that much coding on, but I do understand it's basic architecture. Surely the OS shouldn't be consuming that much power. It should be waiting on a listener to be triggered by an event?
The Cell Standby surely should be the only real service that's active. Google framework has nothing to do as the watch was disconected [from the Wear App], which means that Google isn't recieving or sending an messages as there's interface to send them through?
Barry
@chris2outwright
You are aware that this is a user based forum right? you should contact Sony directly >>> Local support not through social media.
Test both devices on safe mode and also download speed test and report back, keep in mind that the Z5 Premium has a 4K display
@read
We'll need more info to better assist you
charge the phone 100% use it as you normally would then once the battery reaches 10%
settings > power management > battery > take screenshots of:
1. the list
2. tap on the graph and take a screenshot
3. back > tap on the top 4 items on the list > take a screenshot of each
post them all here or upload the screenshots to box or dropbox or google drive or etc and post the link
read
No problem, but you might be interested that it only happens when an interface is enabled. Last night I charged the phone to around 97% and put it on airplane mode. These are the battery stats..Screenshot_2016-02-04-07-20-12.png
read
Additionally, just as a general battery performance thing, I've just got up [ with 87% battery] at 7:14am, it's now 8:14am and my battery is at 74%! Is 10% In one hour normal, because that would.pyt my battery life expectancy at around 10 hours with all battery saving options on!Screenshot_2016-02-04-08-15-38.png
read
And with less than an hour of browsing @ 8:54am, my battery's down to 63%! Is this normal?
