I'm having an issue with my Z5 Compact when unlocking the screen. (Specially in dark rooms). The colors are totally "washed" for a few seconds, until adaptive brightness starts to work.
Sometimes in a dark room (like the bedroom) there is a 50% chance or more of this to happen.
To reproduce this: You need to use "adaptive brightness" under settings. And you need to unlock your phone a few times. I'd recommend you to do this using Tapatalk (Dark theme).
Anyway,
I'm posting this because I've received an update yesterday from 32.0.A.4.11 to 32.0.A.5.32 and the issue is still here.
Should I replace my device? Or just wait for another firmware?
Regards,
Sebastian.
@Rickard
Please, could you give us a clue about "when" are we receiving this fix? (I mean, when is the Marshmallow OTA landing)
I think we waited a long time with this terrible bug. Like more than 5 months with a broken auto-brightness.
Yes, ETA of Marshmallow would be fine...
FIXED with MM 6
I can't believe
I have updated to Android 6 a couple of days ago via an OTA update. I'm on version 32.1.A.1.163 now.
However, the issue still exists if I turn on Auto-Brightness.
On Z5 "standard" the problem is fixed with Marshmallow.
@Rickard wrote:We have found the cause for this and it will be fixed in the update to Android 6.0.
Rickard the bug is still present in Marshmallow.
Now it doesn't occurs when you unlock your device. (Like in Lollipop).
It happens a few seconds after you unlock the display (when adaptive brightness change the brightness based on the current light sensor value) I have been able to reproduce this issue in daylight outdoors using a dark color app. I saved a bug report. Send me a PM so I can share it to you.
The bug is *still* there in 32.1.A.1.185
Seriously Sony, are you even trying?
