Have a z3 there is unfortunately screen lock pin in it! Pin is no longer known! How do I get it back?
If you decided to go with the software repair, then follow the guide I linked strictly. You should have your phone charged and switched off and connect it to PC only when prompted.
Try the steps in this thread first, but if it didn't work with you then the only way to regain access to your phone is performing a software repair using Xperia Companion. Sadly, you'll lose all your data.
