Z3 change device Name
Nash07
Hi
I want to change my device name from my Xpeira Z3 Compact.
I mean the name which is shown when I look with another device to find my Bluetooth, WiFi-Connect or my Hot Spot.
For the moment I get an technical name like: "Xpeira Z3 Compact_b325"  I like to change it in a name that makes me specificly find my device.
For example like "Z3_[myName] _007"
Other Android Smartphones have this somewhere in the device settings but I could not find in my new Z3 Compact.
Thanks for your help.
regards
Nash07
Thommo
Genius
Settings then More then Tethering and mobile hotspot then Portable Wi-Fi hotspot settings then open the top option Configure Wi-Fi hotspot
5 REPLIES 5
Nabeel
Hi
Go to settings > bluetooth > turn it on > tap on the 3 dots ( Options key) and select rename device
Nash07
Hi Nabeel
Thanks for your replay.
Thats the only thing I found out myself.
But the Hot Spot still shows me the device as "Xpeira Z3 Compact_b325".
Where can I change this?
regards Nash07
Thommo
Genius
Nash07
You're my hero, thanks a lot :smileyhappy::smileyplus::smileycool:
Rush365
Hi there
For some odd reason, "rename this device" is greyed out?
any reason for this or workaround?
