When talking on my Z2, people say that they can hardly hear me. I did contact Sony who informed me that this is not a known issue with the Z2 and that a software repair should resolve the issue, however after running the PCC repair, I am still facing the same issue.
Z2 details - UK 4.4.4 - 23.0.1.A.0.167.
Any advice would be most welcome.
Regards
Steve
Thanks for the suggestion. I have tried it both off and on and there seems to be little difference.
Is this through regular phone calls or skype or other apps?
Hi huggons,
Discussion Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
Have you made sure that the mic section is clean and free of grime and particles?
Regular calls and the holes are nice and clean/clear
If the issue is consistent after all the troubleshooting, then I can only suggest that the handset be checked by a service agent. use my signature below to find appropriate contact details.
Not sure I'd recommend, sent mine in to be fixed for a dodgy microphone and it just came back with physical damage to the casing, and a broken magnetic and usb port.
Hi DLwaters,
I suggest that you contact Sony Mobile within your region and make them aware of this, they should be able to help.
Use my signature to find the contact details for you region.
