Z2 dont start and boot loop SE screen
Engr
Dear All,
It has been now 4 months i have this Z2, unitl now everything was working fine, last day the battery drained completely, 0% and it got off. after some time i connected the phone to wall charger using original charger and cable , the screen boots and sony xperia flash and then it get off and then again keeps boot loop,
The RED led comes on and then off , and screen flash SE and keeps looping... i tried making power off holding UP + power nothing works.
i tried connecting to PCC but it also doesnt detect and keep searching phone. i tried repairing using PCC but it doesnt detect phone. i tried holding DOWN volume during power on but green led doesnt come ...
 when i press UP + power on , Blue LED comes but nothing happens.
dont know wht has happened, kindly suggest me what to do.. im unable to use the phone or powere on or im not able to do anything.
Await your best support at earliest.
Wajid
14 REPLIES 14
Thommo
Genius
Depends on how long you have had it but for me in the UK I'd return it back to the place of purchase and get them to deal with it as my contract of sale is not with Sony - The store will have a contract of sale with Sony and when the store accepts it they will, well here in the UK check the device and give you a certificate noting any defects etc so anymore damage incurred is not down to you but the store
Engr
Thanks both, let me try contact the dealer, and in meantime if you can get some more clues or things i need to do, kindly send msgs...
will update soon...
Regards - Wajid
Engr
Hi ,
I went and gave the phone to the dealer , he says there is moisture inside phone, and cannot be covered under his dealer warranty. 1 month before i used this phone in pool water to take pics, but it was working, i didnt have any issue, but dealer says there is water inside.
However, phone was returned back to me, then i went to service center, they opened the phone and just he removed the battery and connected back. screen started and then gave a message please connect the phone to PC, software update failed.
Then i connected the phone to PC companion, made repair phone, all went well and now the phone is working good.
i have noticed now that battery is draining little bit faster. i mean when i kept the phone in 96% charged, airplane mode, no wifi,  kept it unused for full night and morning i noticed battery has 86%, almost 10% drained without any use. i dont know it is normal, but it is draining so fast even when phone is in airplane mode, no wifi, .....
However, Now the phone is working ....Thanks to all.
Abuje
I started PC companion without connectiong the phone, then when it prompts to connect, before connecting i pressed Vol UP + power on button for 10 secs, it doesnt vibrate,
then i connect the phone to USB PC while continously pressing Vol down ,... nothing happens, PCC keeps searching my phone... and RED led comes ON and thn green blinks then gets off , then again RED comes on ...loop...
phone keeps restartings, RED led gets on, thne green blinks,then no led,... then again RED led gets on...loops....neithier it charges,neither it gets off,nothing happens.
Thanks again.
mu13
assalam.o.alaikum janab mra mobile sony charging pr bhi display show nhi kr rha hai or ma panel bhi check kia hai or battery bhi change ki hai or agr b attery inkal kr charging pr lagata ho to display show kr or agr battery lga kr power ka button press krta ho to red light show krta hai
If you do not show the display of the mobile phone or charging of the mobile phone, you can check whether the battery is changed or if you are using the charger at the time of charging, show kr or agr battery will be displayed. Press the power button to show the red light.
gt
