Xperia Z5 Compact not charging
fullereno
Hi, I have a Sony Xperia Z5 Compact that worked perfectly. Five days ago, the mobile ran out of battery and, after two hours plugged in, the phone started charging and it worked perfectly again. But two days ago, it ran out of battery and since then it does not turn on. It was several hours connected to the current, but all the time showed the image of no battery and then the white screen of Sony Xperia, as it was turning on, but returned to the image of no battery, and like this in loop. The only thing that I was able to do was to load it a little bit by putting it in flash mode with the LED light green while it was off, but after several hours it only charges around 15% and when I turn it on it does not charge, I have to wait for it to turn off and start over.
I hope you can help me and thank you very much for your attention.
@fullereno
I'm sorry to hear about the issue, but you will have to contact your Local support to get it inspected/repaired.
