Hello
My screen keeps turning off every 3 seconds even when using my phone. I tried extending the sleep time but regardless of the time chosen it turns off the screen within 3 seconds.
I then turned off Stamina mode and it seems to be fine now. But now my battery will die faster without stamina mode. The long lasting battery is why I chose an Xperia Z3.
What needs to be done so I can keep Stamina mode on but have my normal sleep setting?
Thanks
Try the following: disable stamina mode, go to settings-apps-all-stamina,force stop and clear data. Restart the device.
So what you are saying is that after you enable stamina and the device goes to sleep,it restarts ?
This seems legit.
But it would appear after doing this I no longer have to use stamina option.
I'm getting 2 different predictions about battery life? Is this normal for the z3?
You will get a battery life prediction with and without stamina.
