I have an Xperia Z3 with a cracked screen at the bottom, less than 1 inch long. The screen only responds to touch where it is cracked oddly enough so I can only use it by plugging an external mouse into it which is not ideal.
My question is, if I just buy a glass will the whole screen work again? Or will I also need to buy a new digititizer?
The glass seems easy enough to replace, the digitizer seem a bit of a pain in the behind.
Thanks
I was looking into it further. What a shame, I can get the parts for cheap enough (around £15) and it looks simple enough from the YouTube tutorials but I don't think I have the time and/or patience
Cheers mate!
I do not suggest changing the screen. use it as long as You can. After I changed mine, i had a lot of problems. The screen would go black and I can not take out the battery...or sometimes I can not end the call if they don't hang up on me.
