xperia z won't turn on and can't charge.
echa
My phone suddenly won't turn on. I've tried to charged but it wasn't charging coz the LED lighting is not working.
What happen to my phone ? Any solution u can share to me ? i need your help..anyone that know how to solve this problem.
Thanks.
135 REPLIES 135
johnrdorazio
FIXED!
I had this same problem, my phone's battery had drained completely and would not charge or turn on... L0CKEY's solution worked for me!
-> HOLD DOWN THE ON BUTTON AND ONLY THE ON BUTTON
-> WHILE HOLDING DOWN THE ON BUTTON, PLUG CHARGER INTO THE WALL SOCKET
AFTER A FEW SECONDS THE PHONE SHOULD START CHARGING AGAIN!
raytali84
that's error hapen to me and fix by open cover baterry and un plug connect baterry and  reback again >>>>>>>>charge again <<<and i use it now >>>>>>>>>sorry for bad english
DHing
I've been fighting this issue for the past few months, this is what worked for me.
I've used chat support (horrible) and I've used phone support (Also horrible, even talked to a manager) in every situation if the power + up doesn't work, they advise taking it in for service whereby they will have my phone for X number of weeks/months and then I get it back, and judging from the number of posts, the root cause is never addressed, therefore IMO sending it to service is a waste of time until Sony acknowleges the problem and has a proper solution. (Not Likely, but I would be thrilled.)
I've tried all of the following with no success:
- Holding down the power for a few min, then plugging in the phone
- Plugging in the charger while the holding down the power button
- Trying to hold down the power and up button
Things that have worked in the past:
- Leaving the phone on the charger for 24+ hours (This didn't work this time)
- Leaving the phone unplugged for 72 hours (Didn't have that kind of time)
I'm not sure why, but I have to use my iPad charger (2A) to charge my phone. If I plug it into the stock sony charger (I think it puts out 1.5A) the phone tells me it's discharging faster than it can charge, and no apps are running other than the stock apps.
Process:
1) Connect the charger to the phone.
2) Get a double A battery, and hook up some leads to it (You can secure them using tape)
3) Connect the positive lead to the docking terminal port nearest the USB charger port
4) Connect the negative lead to the docking terminal port fartest from the USB charger port
WARNING: I'm not 100% sure on the positive and negative connections here, when the light came on I was so happy I threw down the battery, so it's possible I got them mixed up from memory-- Verification from another brave soul would be helpful!
The red charging light should almost immediatly illiminate, if it does not you may elect to increase the power voltage (by using a 9V) but I didn't need to do this, and I'm not sure the results.
Actual milage may vary and this could very well blow up your device. YOU HAVE BEEN WARNED. In my particular situation based on the above arguments I didn't see a point to service (And likely the time it takes to get to service would have discharged the battery sufficiently). I actually need my phone to be on call, and thankfully this happened on Sunday and not Saturday WHILE I was on call.
Based on my experience with this charging issue and the kitkat upgrade that forces the most restricive security policy on some versions of Exchange, I would not recommend Sony mobile devices, but now that I have one, I'm stuck.
Keep your batteries charged kids. If this solution helped, please consider giving Kudos!
kiwi101
i had 20 % of battery left so i pluged cable to charge so as soon as i plugged the cable in the mob got it got switched off and now its not turning back on please help !!!     i have tried everything all kind of reset but still it wont work
kiwi101
any one help me please !!!!
profile.country.RO.title
_alexdon_
Connect to wall socket,force restart(power button+Vol up until the phone vibrates).Let it charge for 2 hours.
alexdon
kiwi101
i have tried that my mob is not viberating
_alexdon_
Then just keep it connected to wall socket for 2 hours,repair with SUS after:
alexdon
kiwi101
i have connect my mobile for about 1 hour it feels like thr is no current passing thru nor my mobile is getting heated nor the charger
_alexdon_
Try a repair directly.If that does not help,stop by a sony service:
alexdon
