After update to firmware version 14.3.A.0.761, I have had problem of connecting to WLan network.
I have successfully logged on to the network, but it does not connect to network but is set to status saved.
The signal strength for the network is good.
Maybe helpfull:
Remove the credentials of your phone from the router: remove all so that your router does no longer remember the phone.
Remove the credentials of your router from the phone: forget your wireless access point in the phone.
Search for a "new" wireless access point to connect your phone to. Enter the WPS-code etc. (If the phone is still able to connect automatically the first time, you haven't cleared all data : do it again and repeat).
Now it should work ok.
Worth a try ..... :smileysmileywink:
The WLan problem started immediately after update to firmware 14.3.A.0.761. Before that update I had no problems with the WLan connectivity.
When I try to connect to wlan the signal strength drops when the mobile authenticates to wlan, but in the list of available wlans the signal strength looks good.
I have no trouble using the same wlan with a MS Surface computer.
I have just done a factory reset of the phone without any luck.
Maybe helpfull:
Reset of the wireless modem, and 2 re-connects from the phone => problem solved
