In new version of Android 6 z3 the phone speed very low and signal wifi very weak is very bad please fix the bug
this is a known bug, so there is nothing we can do at the moment but to wait for an update fix.
@Rickard wrote:You might experience that the Wi-Fi coverage in the Xperia Z3 and the Xperia Z3 Compact appears to be weaker than before the upgrade to Android 6.0. However, the reception is not weaker. It's only a perceived Wi-Fi coverage downgrade, due to a bug in how the Wi-Fi bars are calculated. This is a known issue which will be corrected in an upcoming software update.
Could you elaborate on how the phone is slow?
Im quite positive it's not just the signal bar (D6653). In android M I can't connect to the same WiFi signals that I could in Android L in university, where as my laptop is unaffected. Similarly at home, I keep disconnecting at points where Android L showed one signal without disconnecting. Moreover, the signals fluctuate from full to 1 bar when i'm very nearby the wireless router.
P.S Same wifi icon in safe mode.
same with me wifi range is weaker,
try to forget and then reconnect with the router
do power cycle
a first few days, it would be slower since most app still need to update and therefore use the network
