When I plugged in my Sony ex earphone and started listening to music using movie or walkman apps, the volume increase itself to maximum itself. I thought I accidentally pressed the volume key but it doesnt. What can I do to solve this problem? Anyone also face this issue? It happens quite often these few days. is it due to hardware faulty?
Please try this and let us know if the problem continues:
Main Menu > Settings > Apps > Smart Connect > Clear data.
done the above steps. now when i plugged in the earphone , a pop up from smart connect appeared showed the earphones is connected ,
