Unable to connect with Dualshock 3 controller
020988
Hi all,
I bought a ps3 controller yesterday for play game on my sony z3.
I tried to pair them in order below:
+ Connect ps3 cable with OTG cable.
+ Open setting _ xperia connectivity_ dual shock series_ dual shock 3.
+ Connect OTG cable into z3.
But there is no operation in my phone. The "next" was not appear.
My phone is D6653, build 23.4.A.1.264. Unroot. It work when i tried with sony z2.
Please help me. Thanks so much.
17 REPLIES 17
020988
Help me please ...:-(
Christofer
Hi @020988,
Are you able to connect any other devices to your Xperia Z3 via USB OTG, a USB flash drive as an example?
020988
It can't be connected with an USB flash. What's wrong with it? 😞
Christofer
That's strange. You are able to connect your phone to a PC and transfer files?
Could you try connecting an OTG device while your phone is in safe mode?
020988
My phone can connect to a PC. It is charged & files can be copied as normal.
I also test while my phone is in Safe mode. It (OTG cable with an USB flash) didn't work.
The OTG cable is again tested with an other Sony device (connect to an USB flash) - it work.
Should i disable or enable the USB debugging? i tried both way but i didn't work.
Christofer
In that case I suggest that you perform a software repair using PC Companion with the help of a PC. Click the blue link and you will get a step-by-step guide on how to perform the software repair.
020988
Thanks Mr Christofer for your support,
I have just performed a Software repair using PC companion. After repairing, my phone still can't connect to an USB flash. the USB flash is formated in FAT32. Is there any problem with Hardware device?
020988
@Christofer wrote:
In that case I suggest that you perform a software repair with the help of a PC. Click the blue link and you will get a step-by-step guide on how to perform the software repair.
What should i do?  Slightly_frowning_Face
Christofer
At this point you have tried most of what you can try on your own. I suggest that you get your phone examined further at one of our authorised service centers. Contact your Local support team for information on how to proceed from here.
