I can not pull down the taskbar section at the top of the screen. It is insensitive to the touch of a 3 mm section of paint from the top of the screen. I do not know how it came to this situation, there is no physical deformation on the screen due to impact. I set the device to software factory settings, but it has not improved. Sometimes it heals itself spontaneously What can be done?
Hola;
Él hizo este test en el mismo celular. Se trata de hacer un recorrido sin levantar el dedo empezando por abajo. En esta captura de pantalla se puede ver que hay una columna que no detecta el paso de un día a otro.
Puede ayudarme, por favor?
Me crea mucho problema en el teclado al usarlo. Desbloquear, recibir llamadas, etc.
Test de pantalla. Sin levantar el dedo este es el resultado.
Hello;
He did this test on the same cell phone. It is about taking a tour without lifting your finger starting at the bottom. In this screenshot you can see that there is a column that does not detect the passage from one day to the next.
Can you help me please?
It creates a lot of trouble on the keyboard when using it. Unblock, receive calls, etc.
GT
Sony care in Ljungby consider that my Z3 is crap due to Sony's bad glue for the screen. Frame and back are ok and I could make phone calls and surf with it before sending it to Ljungby. Sony care wants to sell a "new" Z3 for $500.
Oberes 5tel des Displays funktioniert nicht. Was kann ich tun
Upper 5th of the display does not work. What can I do
GT
Habe schon einige Male neu gestartet
Have already restarted several times
GT
Same problem, but during the diagnostic test suggested by Sony, it works fine. Very strange.
Solucion! Cambio de pantalla completa
Duro como 5 o 6 años sin dar problemas. RIP
Solution! Full screen change
Hard as 5 or 6 years without problems. RIP
gt
I can't swipe down as the top screen is insensitive to touch. I have run some tests but to no avail. Please help me Sony
