Touch screen problem.
Bkdmr
I can not pull down the taskbar section at the top of the screen. It is insensitive to the touch of a 3 mm section of paint from the top of the screen. I do not know how it came to this situation, there is no physical deformation on the screen due to impact. I set the device to software factory settings, but it has not improved. Sometimes it heals itself spontaneously  What can be done?
Tags (1)
Jake-SonyXperia
Hi @Bkdmr,
welcome to the community,
I am sorry to hear about this issue.
To help identify if this is software or hardware I suggest trying to perform a diagnostics test on the device. Please see the instructions below.
Settings > About phone > Diagnostics > Test > Touch Screen.
Let me know what the result is.
16 REPLIES 16
Jake-SonyXperia
Hi @Bkdmr,
Bkdmr
I did the test you mentioned earlier. The upper part does not work as a 3 mm line.
Jack_gecko
Hi I have exactly the same problem, testing is not a solution. Sony please advise, this is not the first time this has been brought up.
I have repaired, totally reinstalled and updated all apps. Please advise a correct solution.
Jake-SonyXperia
Hi Guys,
I am really sorry to hear the outcome of the test. In this case, I can only suggest that you get in touch with Customer Care as the devices may need to be inspected via a repair agent.
Please use my signature below to find contact details for your region specifically.
I am sorry for the inconvenience this may cause.
nbkflorin
Oldleather
Z3 screen looks fine not responding why?
Wecancreate
Same here. Since update last night
sbaena25
I have the same problem. Please, can you write us a solution?
Chriswilson
Since update last week 1 cm on left vertical not working, I've tried everything
