This is the second time this has happened with this phone. I get the error message 'Unfortunately System UI has stopped working' there is only an OK button option. This then turns my screen black and I can't do anything with the phone other than shut it down. This happens even after a soft reset and I don't have the time to start anything before it crashes again. Any helpful solutions?
Hi , you can try this 2 method :
#Method 1
1. Remove sim card , and sd card from your phone.
2. Press the red button which is located nearby to the Sim Card reader with needle for sim or toothpick for about 6 second until you hear vibration then releasse and see if the phone boot's up normaly .
#Method 2
1.Make sure your phone battery is charged
2. Press together Vol + and Power button for few second until you hear vibration then releasse and see if the phone boot's up normaly.
#Method 3
Do a Factory Reset
#Method 4
1.Go to PlayStore and Search for Google Chrome
2. Unistall Google Chrome and Reboot normaly your device.
3.If the problem is stil there , try to Update Google Chrome and do Reboot
#Method 5
-Go to PlayStore and try to install another Launcher for your phone
Good Luck :).
This is related to any new software updates that happen by default by sony.
To resolve this, first enter into Safe mode of the phone system.
Step 1: When you get the power off screen long press power off option on screen to go to safe mode.
Step 2: Phone now restarts with Safe mode on.
Step 3: Reset what's new to factory default. Remove any unnecessary apps.
I have to remove lots of Sony system apps.
This might happen each time, there is a sony apps updates.
