System UI has stopped working
FreyaFaery
This is the second time this has happened with this phone. I get the error message 'Unfortunately System UI has stopped working' there is only an OK button option. This then turns my screen black and I can't do anything with the phone other than shut it down. This happens even after a soft reset and I don't have the time to start anything before it crashes again. Any helpful solutions?
11 REPLIES 11
@FreyaFaery
You might want to repair the phone with XC >>> Xperia Companion
Ibrahim89
i have the same problem did you find any soluotion!!??
i made software repair and problem happened again after 4 days
Littlemanpoop
I've been encountering this problem recently as well. It happened as frequently as twice a day and seeing that nothing's working, I'm scared because I don't have money to get another phone either...
AKGEO
I keep getting system UI has stopped message. I switched on some features for some Apps and now it won't let me switch them back. Now some other Apps won't work properly.When I get system UI has stopped message the only thing I can do is restart the phone.
How do I solve this?
beast-61
Double tapped my screen the other night and it was blank hit the power button and got the clock back and said that the system u I had crashed I restarted it and it happened again but since I've turned it off and on again it's been fine looked in settings support and it said that my system u I had crashed and took me through what to do but seems fine now anyone else had this problem and what causes it thanks ppl.
beast-61
Don't know tried to follow on screen instructions and some of them which I need to use won't let me so don't know what to do need some help cos it's happening more frequently.
beast-61
If we're all having this problem ten there must be quite a few more ppl also may I suggest some kind of virus.
riek87
I have the same problem. It happens every time I try to use the volume up button on the side of my phone
Tags (1)
100660PK
Vypína mi mobil preblikava červená a šedá obrazovka a vypisuje :
Lutujeme aplikácia UI systému prestala fungovať.
Ako to vyriešiť.
Turns off my cellphone blinking red and gray screen and writes:
We grind the UI system application stopped working.
How to solve it.
Gt
