Is it possible to go throught startup guide on xperia z5p without factory reseting device?
Hi @Xperiaman007,
I'm afraid that there is no such option in the phone that will allow you to do the start up guide again, unless you perform a factory reset or by performing a software repair using Xperia Companion.
Is there anything specific that you need to do in the start up guide?
Let me know what you want to do and I will have a look at it!
Yes i need startup guide because i can only choose serbian (cyrillic) language there but when i restarted phone it has gone back to english i now i can not find serbian (cyrillic) language in settings/languages it does not exist there. I can only find serbian (latin) which is translated half from english and it is bad. Using android nougat 7.0
Oh, I see!
Do you have any other language options after you press on Serbian? It works a bit different in Android 7.0 and some languages that have more than 1 option you have to press on the language first and then you see another menu where you can choose for example "Latin" and other options.
For example if I press on "English" I can choose "Australia", "Canada" and so forth.
Let me know how that goes!
There is only serbian (latin) and when i enter there is option for Bosnia and Hercegovina, Montenegro, Kosovo and Serbia i try all of them but all are the same half of menu is stays on english and also apps ( only one language selected Serbian ) . With Serbian (cyrillic) it is perfect all is translated menu and apps all good but i cant choose it now in settings because it does not exist there i could only choose during startup guide.
Thanks for the update and for the great information!
I can see that you raised the same question to my colleague Christofer and this is being look in to.
He will update you once he have received more information regarding the translation in Android 7.0 when the system language is set to Serbian.
I'm sorry for the inconvenience this may cause and I thank you for your patience.
Thanks and i hope this will be resolved in future update.
