If the data isn't disabled after 15 minutes (time after stamina kicks in) , you should try this: first,make sure it is disabled, then go to settings-apps-all,scroll down to stamina. Tap on it,force stop and clear data. Restart your device.
Also,see this:
/t5/Xperia-Z3-Z3-Dual/Problem-of-mobile-data-in-stamina-mode/m-p/942095#M10023
Hey
The data and wifi are disabled only after the phone has been locked ( screen off ) for about 3-5 minutes and both are enabled instantly when you press the power button to use your phone.
Also,see this:
