STAMINA mode and notification LED
wrealcon
Hello,
Is there any possiblity to set up STAMINA mode in such way that notifications LED would be used (incoming sms, missed phone call, etc.) ?
Best regards.
Rickard
The notification led is currently disabled in stamina mode and i don't know of any way around that. I believe this will be changed in upcoming updates for the phone however.
7 REPLIES 7
Rickard
hacker02
When We set the power management to stamina mode,it does not allow notification led to notify..is there anyway to turn on this notification light during stamina mode?
hacker02
Alexander1
Unfortunately the LED notification will not work when you have stamina mode enabled.
kabauterman
This is not really ture so far.. the LED Works but I dosn't work with an external LED Tool Like Lightflow, even If I choose this App to be Active in Stamina Mode
€: talking about Z2..
kabauterman
Hey Guys,
unfortunatly the Notification LED is not able to work right when the Phone is in Stamina Mode,
I use LightFlow to control the colors and even if a say LightFlow and the other Apps I want should be active in Stamina Mode, the LED just shows the usual Sony style blinking wich is not really helpful at all.
Is there any way to make the LED working in Stamina Mode, like it works without Stamina Mode?
Thanks in Advance
