Sony Z3 camera module compatibility with Z1 AND Z2?
antebag
Hi!
I want to know are camera modules on sony Z1,Z2 AND Z3 same? Can i buy sony z1 camera module and put it in sony z2 or sony z3?
Or vice versa?
12 REPLIES 12
@antebag
I'll try to get you the info, but in the mean time, you can't
antebag
Its little weird that nobody tried this before.
I dont see a reason why sony z3 cannot accept sony z2 camera module?
They are identical, atleast on pictures that i found on internet. They have same number of pins and same connector. Those camera modules have same specs in every way.
Main reason for this question is that sony z2 camera module is twice cheaper, but they are same, atleast what i can see.
Lord_viridis
I believe Z1&2 are the same but Z3 is different.
However, revisions of hardware are subject to change so I cannot say for certain 100%
Even MX2XX sensors evolved over time with various housings and connections as the phones were made thinner.
Z1&2 used IMX220
Z3 used IMX220 with newer lens array =25mm
Your best bet is to contact Local support to clarify
antebag
Here are specs i found:
Sony Z1  -  20.7 MP, f/2.0, Focal length 27mm ,    1/2.3" sensor size  ,Pixel size   ?  μm
Sony Z2  - 20.7 MP, f/2.0,  Focal length 27mm,    1/2.3" sensor size  ,Pixel size 1.12 μm
Sony Z3  - 20.7 MP, f/2.0, Focal length 25mm,     1/2.3" sensor size   ,Pixel size 1.12 μm
profile.country.PH.title
MarlonUk1
@antebag, this might not be the same with the models you inquired but I had the same Idea for the X series.. https://www.youtube.com/watch?v=50VcrOKJnN4&list=PLM3XYRzu8pIEsUC-f_S7SmQlrL96tfFyt&index=23
antebag
omg, great video. It would be great if someone who have z1,z2 and z3 check camera compatibility between them.
Lord_viridis
I wouldn't recommend it.
Z3 is a different module partly due to the fact the housing is thinner to fit in the thinner Z3
@nolramlb's post refers to two identical cameras released at the same time on the same series X device (Z1/Z1c etc).
Mič_SI
I have installed z3 camera on z2. It works.
EndiGorjan
i replaceda a z1 camera with z3 camera and it works Winking_Face
