Slow camera on lollipop 5.1.1
Xperiano
Why viewfinder camera is slow than kitkat?? Camera refresh rate look lower than 20 fps on medium or low light conditions. On kitkat looks to be 60 fps!! Please sony fix that!! It's the worst thing on an update like this
projectus
I'm also experiencing such problem, on KitKat the viewfinder was much more smooth than it is on 5.X...
Only in video mode it is still fine, but it photo mode it is not appropriate... Was hoping that 5.1.1 will fix it, but it only added a no-ringtone bug.
14 REPLIES 14
@Xperiano
Which Xperia do you have?
Xperiano
Z1 Compact D5503
Xperiano
If you only start the camera (dont use it), and just shake, camera so lagging on 5.0.2 and now also on 5.1.1. On previously kitkat firmware, work fine. On this video you can see the issue:
https://www.youtube.com/watch?v=sMI1qpgD7TE
@Xperiano
Let's try something basic
reinstall the latest update with PCC and also save the videos/pictures on the internal storage and report back
PC Companion (PCC)
Bridge (for Mac)
Xperiano
I had tried this before and the problem persists
Xperiano
This is very annoying!!! Please fix this software issue on another update! Thanks a ton
@Xperiano
Where are you saving the videos?
Xperiano
This error has nothing to do with where videos are saved . it is software problem. Please fix that on next update. It's very annoying!
@Xperiano
Could you post a video of the issue so it'll be easier to understand the problem?
