Screen overlay
Mickyblue
Screen overlay
Just updated Z3 and keep getting SCREEN OVERLAY DETECTED message. Turned off all permissions in all apps in settings list it takes me to but makes no difference. Even going to back up my phone and reset but that gives same message as well. Only email not affected is Gmail of course.
39 REPLIES 39
Mickyblue
No. Just get the same message ' screen overlay ' if I try
@Mickyblue
Settings > apps > gear icon > Draw over other apps > look for the apps > tap > enable.
Mickyblue
Done that but still can't add calendar to email or contacts to Outlook
profile.country.RO.title
_alexdon_
Mickyblue
Won't let me😣😣😣😣
It's nearly every app on my phone might as well get a Nokia 3210 even Wap push has fault. Can make calls and send text messages can't even take photos
_alexdon_
@Mickyblue Do you have clean master installed? Can you check if the same occurs in safe mode?
alexdon
Mickyblue
Did have clean master. Just removed and everything working OK now.
N91
Hy, i am also having the same problem. You can solve it by switching your phone to safe mode and then go to apps>> draw over other app and then turn off all.. Then after go to app which show screen overlay problem and give them all permission it need and restart your phone.
Dray1
Why does Clean Master cause these issues?
Sahilk297
Whenever I can open a software and download something its not working properly and its me again and again to change your app permission. So, there is any suggestions or probably solution for this error..
