Hello, if I want to make the Z5 a call and dial the number and pick up the phone, the screen goes black and I can do nothing more. It then responds to anything, not even on the Power button until the other ends the call. Then, the screen lights up again and it goes back all normal.
Hallo, wenn ich mit dem Z5 einen Anruf machen möchte und die Nummer wähle und den Hörer abnehme, wird der Bildschirm schwarz und ich kann nichts mehr machen. Es reagiert dann auf nichts, nicht mal auf die Power Taste bis der andere das Gespräch beendet. Dann wird der Bildschirm wieder **bleep** und es geht wieder alles normal.
Happens to mine as well. I have no screen protector!
I have the same issue and actually today without making a call my phone went black and wouldnt respond to anything. i had to press home and volume button to get it to come back on
very frustrating!!
I have what seems to be a common fault with the proximity sensor always thinking that my ear is by the phone, so my screen goes blank as soon as I try to call somebody.
Having searched these forums I tried the solution of backing up my phone and doing a factory reset. However, this hasn't cured the problem and I can't remember seeing any advice on what to do if that should fail?
Thanks in advance
Does your phone has a protective film, glass and/or cover?
No, nothing is on my screen. I have just noticed it temporarily fixes itself if I press hard over the sensor then release, but only for a very short time. Don't know if that is relevant at all...
Settings > about phone > diagnostics > test the proximity sensor, and it'll be wise to contact your Local support
Thanks for the link, I'll get in touch with them.
