I want a solution..?
Low ringing sound is very bad.
what should I do?
I did the factory reset and safe mode did not change anything.
Music and video Sound is normal ..
It is the fault of sound picked on the device..?
I do not know what you mean?
Do you mean a developer?
I have a same problem...when phone is ringing, volume is lower than when i play etc. music from speakers....
Yes.that is true...even ı don't hear the calls many times and my friends doesn't reach me by phone. And that situation makes many problems in the world of advanced communication
Especipaly ı do not hear the phone while ı am out or the phone in my pocket the phone level is end..
May be a solution that problem even it is any where but no one reach and serve?!!
I have continued with the support team in my country.
I did everything I was asked.
It was said that there was a bug inside the phone.
I am sure that the bugs of the update are Noga and Marshmallow.
Lollipop did not have this problem.
The company's policy is to hate you by phone to buy a newer phone.
I have a similar problem. After installing the volume update, the melody of the incoming call became slightly lower. In the player or in the video, the volume is the same as before. The reset to the factory settings did not help, nothing helped. The forums did not find a solution.
У меня аналогичная проблема.После установки обновления громкости мелодии входящего вызова стала чуть ниже.А в плеере или в видео громкость как и прежде нормальная.Сброс на заводские настройки не помог, ничего не помогло. На форумах решение не нашла.
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
