Hi good day. A week ago the battery began to fail. I do the full charge and I start using it, when it reaches 50% it goes off and tells me that I do not have a battery but if I plug it in and unplug it without charging it, it keeps going. At 27% he does the same again. What can it become?
Hola, buen día. Hace una semana empezó a fallar la batería. Hago la carga completa y lo empiezo a usar, al llegar al 50% se apaga y me dice que no tengo batería pero si lo enchufo y lo desenchufo sin darle carga sigue andando. A los 27% vuelve a hacer lo mismo. ¿ Que puede llegar a ser?
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
You might want to contact your Local support to get it inspected.
