There is but it's probably not as you remember from other makes- So 1st you need to save the contact then once saved open the contact and tap the edit icon in the top right corner then tap the 3 dots and select send to voicemail and save
You can only add a number to your contacts and always forward to voicemail.
Hi, the Z2 does not have a function to totally block calls.....only as mentioned to send them direct to Voicemail, you can however as i have had to do in the past activate a 3rd party app from the Play Store & this will work :smileysmileywink:
