Hello, every night, the battery is discharged to 30% charged last night and again discharged, the battery-to-use writing, most battery consuming "OC Android", what to do?
@Mixadance Boot your device in safe mode, check if the same occurs. There might be some apps keeping the phone awake.
I am facing this problem.
Yes i am trouble with this battery
