Proximity sensor issue resolved :)
phantomrocks
Big daddy resolved it Slightly_smiling_Face
You have to sacrifice resetting the phone using the Sony PC software 1st. Avoid data backup from old accounts.
Then, after the reboot is done and Android is reinstalled with update x.x.x.534 goto the dialer & type *#*#7378423#*#* then press dial
In the menu that will come go to calibration and then choose proximity sensor. (If you run the test it might give error = -1) Then, set settings to default and it may ask to reboot the device.
After reboot type *#*#7378423#*#* then press dial. In the menu that will come go to calibration and then choose proximity sensor do the test and it will show success. VIOLAAAaaaa!!!!
Check the phone...it works Slightly_smiling_Face
Have tested this and the issue is resolved on my phone finally ....yippieeeeeee!!!
76 REPLIES 76
hood
Clever!! Although I don't have this problem, but thanks for sharing!!
phantomrocks
just for those who are too scared to try typing *#*#7378423#*#* on their dialer it actually takes you to the service menu meant for developers/service center agents. It's safe to use for this option and can be searched upon on net before use to be satisfied completely Slightly_smiling_Face
beowolfgoth
Thank you so much!!!! It worked!!!!! ❤️ i was so depressed  , thanks a lot dude ❤️
VIKRAM0512005
Thank you so much, it actually worked........phantomrocks
Aby2009
Thanks a lot for this fix ....it really helped me a lot....
I owe you a beer.....:smileycool:
tenellus
finally my problem is solved
many thanks
cheers Grinning_Face
vinayjs_88
anybody please confirm this is hardware or software problem
phantomrocks
looks more like a software glitch to me. gets resolved after these steps as confirmed. Plz dnt 4gt to give kudos Slightly_smiling_Face
vinayjs_88
Hi can I restore using phone settings and complete the remaining steps please tell me.
This is not a hardware problem right??:seismology's:
