Problems with GPS on Z2
BobC1
Hello!
I got a problem with my Z2 gps system. A few app's say that my GPs is turned off when its not and the weather widget can't find my location, and whem i'm lucky it does but gets it completly wrong, usealy about 15km in the wrong direction. Strangely a lot of GPS requierd app's work fine. Rebooting the phone hasn't worked and re-instal the non working app's neither. At first i thought the problems where in the app's but I find it hard to belive that that many app's have the same problem and also the weather widget that was factory installed doesn't work properly.. Does anybody else had similar or the same problems? and does anybody have a solution?
Phone:
Sony Experia Z2
Model:
D6503
Andriod version:
4.4.2
Buildnr:
17.1.A.2.55
Tags (2)
17 REPLIES 17
Kopleman
I have same problems, GPS doesnt work correctly in browsers(not show my locatioan at all), but works in specifiec map apps like Yandex Maps
Harvz2016
same with me after the 5.1.1 update gps was not working, regarding the GPS Status which was working? I tried searching on Google Play and give me a lot of choices. thanks
SONY  PLS FIX THIS
Harvz2016
I recently upgraded to Andoid 5.1.1. version. (with Sony OTA)
My GPS started not to work after the upgrade.
I did the test by phoning *#*#7378423#*#* and it did the servive  test for the GPS. it cannot anything: it says waiting for location update but does not find anything
Any work arround? SONY  PLS FIX THIS
Ashroft98
Enthusiast
Before doing anything else. Try booting to safe mode.
Safe Mode
Press and Hold Power Button > Tap and Hold POWER OFF > Tap OK to reboot to safe mode
Test your GPS using Diagnostics in Settings > About Phone instead.
Remember to test GPS at a empty road or field and NOT in a building to make sure optimum functionality.
After testing,restart the phone normally to exit Safe Mode.
Harvz2016
@Ashroft98
Thanks for the reply, I try booting on safemode and run GPS and still it was not working.
Below are details of my phone:
Android Version: 5.1.1
Build Number: 23.4.A.1.264
fezinn
Please sont. Fix this.
I'm from Brazil, I have a D6543.
After updating to 5.1.1, I just can't use my GPS. It's causing a lot of trouble to me as I need to work with it! So, PLEASE Sony, fix this!!!
marcioscheibel
Did SONY already fix this? GPS working well in Android 6 Marshmallow?
Ramitha123
I tried that code.but I cant fix my gps problem.I think its a sofware problem.pls tell someone to fix my z2 gps problem..
