Problem with volume sliding bar long lasting time in z5 dual
r3z4x
Whenever i press the volume button to increase volume up or down in any case, like when watching a video or listening a song or during tge call.., the volume sliding bar appear in top of my screen, but it takes very long and unusual time to be disappeared from the screen. Or i have to touch anywhere in screen to disapper it immediatly.
I am haveing this problem for last 3 month,
Before that, it worked correctly,and dissapear in normal and short time,and no need to touche the screen to disapear it.
What should i do?
And what caused this problem?
r3z4x
Thanks
After starting up the phone in the safe mode, it remained normal.
And now it disappear in normal time 😉
5 REPLIES 5
Didrik
Enthusiast
Hi @r3z4x,
How long would you say it takes before the slider dissapears? Are you experiencing the same thing if you reboot your phone to safe mode?
r3z4x
@Didrik wrote:
Hi @r3z4x,
@ hi @Didrik
it takes 20 sec to be dissapeared from the screen. for disappear it immediately i have to touch somewhere in screen.
 in safe mode, it works normally, and takes 3sec to be disappeard.
so what is the problem?
Didrik
Enthusiast
@r3z4x,
If there is that much of a difference while in safe mode I'd say it's safe to say that one of your downloaded apps is the culprit here. Unfortunately it's hard to say exactly which one it is.
I recommend that you start by updating all of your apps. If that doesn't help then you may unfortunately have to uninstall them one-by-one. I know this might take a while to do, a tip is to start with the ones most recently installed.
r3z4x
Thanks
Didrik
Enthusiast
Glad to hear it Slightly_smiling_Face
