Hi
I'm trying to use Xperia Moblie Transfer app on Z1 Compact to transfer content from Xperia S (running 4.1.2), but can not get it to work. When pressing "touch to beam" in app on Z1 a message appears on Xperia S saying:
New tag collected
text/plain
text/plain
and nothing more happens.
Suggetions??
Regards,
Anders
I checked and at the moment Xperia S is not supported by Xperia Transfer Mobile. When you scan the QR code in the Z1 Compact you will get the Xperia Transfer app (not mobile) instead.
Try using PC Companion and the Xperia Transfer option which will transfer item from your XS to your Z1 compact
That option works fine , but I was under the impression that the newer "mobile transfer" option transferred more of the data from the old phone?
