Problem with battery level
nikefursov
Батарея телефона держит гораздо дольше если его заряжать не родной зарядкой. Раньше был телефон Xperia z. После года использования наблюдал тоже самое что и сейчас. Может ли быть такое?
The battery of the phone holds much longer if it is not charged by a native charger. Earlier there was a phone Xperia z. After a year of use, I watched the same thing as now. Could this be?
GT
exsanguinator
The "mah" of the battery determines how long the battery will last, and that would decrease in time over years.
The "A"of the charger determines the speed of how quickly it charges.
Most phones with 4000mah batteries would be supplied with a 2A charger as a minimum.
Most mid range and up phones have a 1.5A charger nowdays.
You can still use older 0.8A chargers,it just takes very long to charge, that amperage is still higher than the trickle charge the phones default to accept when the software notices the battery is fully charged.
These are basic laws of electricity and can't be changed,
