No connection with pc
Hanneke
I tried several cables but my pc cannot connect to my Z5 anymore.
It gives Code 28, no driver installed.
The phone indicates the programmes are up to date.
Is it possible to connect without cables? I need to download some stuff from the pc to the phone
Hanneke
2 REPLIES 2
disimes95
Hi!
Did you try uninstall and reinstall Xperia Companion?
Snowman-88
Good day!
I have the same problem.
I had been reinstall the Xperia Companion, but result the same.
If choose only charge in phone - have not a charge via USB
If choose the "Transfer file" or "Ue device as MIDI", than  start charging, but PC do not see he phone again
Thank you
