I bought a Z5 the other day and I haven't tried NFC until I got me a scr42 style cover for it. I noticed the smart window function doesn't work and realised that the phone doesn't display the NFC icon in the status bar. I've tried activating NFC from both the pull-down menu and the settings and in both the option lights up as if it were enabled, but the icon does not appear and the phone doesn't react to the tag on the cover. Is there something I'm missing or is this a known problem with an android version or the phone itself?
Same scenario here, NFC of my Z5 is not working only i received this one last friday Christmas. NFC is on but i cant transfer any photos or videos from my Z1 to Z5.. Z1 NFC is working but Z5 is not.. can you help me. i remove the cover already but still nothing happened.
i can't found the nfc test on setting/support/diag/test
Добрый день!
Я раньше не пользовался, а недавно поставил Google Pay и у меня проблемоа:NFC не включается, галочка ставится на секунду (или несколько секунд) и пропадает. Через виджет включение тоже не работает.В сервис-меню, тест NFC выдает: "The NFC device can not be used"....
Good afternoon!
I have not used it before, but recently I installed Google Pay and I have a problem:
NFC does not turn on, a tick is put for a second (or a few seconds) and disappears. The inclusion also does not work through the widget.
In the service menu, the NFC test reports: "The NFC device can not be used" ....
gt
Sir I on my NFC but it's not showing on display how I know it's working or not
