You are welcome,which version did you choose?
@TheTipsiz wrote:
Nooo. The issue is back again.
Hi there,
Contact your Sony Xperia Care and advise with them in order to solve the problem at the best way.
Perhaps you should to carry the phone for repair?
Cheers.
form the first day i bought this phone i have problem with the camera
some time it's freez and i have to turn the screen off and on serval time
i bought this phone with kitkat
any idea ?
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
