The rubber seal will break due to wear annd tear, which is normal for all waterproof devices.Especially when we have to open and closed it frequently, like the earphone & usb port cover. =x
You can actally buy replacement port covers from ebay. Or you can go back to the service centre, although it won't be free, or cheaper. But at least you know it will be waterproof after that.
Guys, had a replacement of the flap at Sony Service Centre. It only took 5 minutes and RM 34 and is as good as new again and waterproofed. And yes, this defect is not covered under warranty as its a wear and tear item. Problem solved. Thanks for the comments and solution given guys.
They dont replace the flaps...the guy at chaitanya electronics chinchwad, Sony's authorised service centre said to me that they can replae only the phone and no spare parts..he himself using the xperia z with lose flaps..dont buy any sony product
Had it less than a month having this problem so dont think it can be wear & tear, just a bad design
