Messaging app problem after lollipop update
Ashhabah
Sup guys ,
after I updated my Z1 to Lollipop a weird problem occured .
whenever I try to delete a conversation it get stuck at this screen fit too long almost 2 minutes , even if it has only one message inside ,
Any ideas ?
Thanks in advance
13 REPLIES 13
Hampus
Could you let history eraser work for a longer time without force closing it? Even if you get a message where you can choose to close the app, just let it work for a longer time (for example during the night) and hopefully this can help.
Otherwise, I think a factory reset is needed in this case which will delete all the messages.
Ashhabah
Ok Hampus I even did a factory reset . messages
conversations got deleted smoothely , but whe I restored the old messages the problem occured again .
does this mean the conversations a bit too much
Hampus
Then it sounds like it is a bit to many conversations/messages if it worked smoothly after the reset but not when you restored all the text messages.
Ashhabah
OK then I will try to bear with it , although this problem didn't happen with kikat
Thank you very much
Tags (1)
