Lcd problem on the whole z3 compact range
Grissa
Bonjour,
J'ai 3 natel Sony xperia z3 compact qui ont le même probleme: LCD qui ne réponds pas totalement ou partiellement. Les 3 sont modérément utilisé, un même était en réparation!
Notons que Sony xperia z3 compact est la haute gamme de Sony.
Je pense qu'il s'agit d'une faute dans la conception:
Sony utilise un ruban adhésif au lieu de visses pour tenir le LCD collé. Avec l'utilisation ou la chaleur (poche, main...) alors il commence a se détacher.
J'aime qu'on réunisse nos effort pour porter plainte contre Sony car c'est honteux quelle continu à opérer dans le secteur de smartphone
Hello,
I have 3 natel Sony xperia z3 compact that have the same problem: LCD that does not fully or partially respond. The 3 are moderately used, one even was under repair!
Note that Sony xperia z3 compact is the high range of Sony.
I think it's a mistake in the design:
Sony uses an adhesive tape instead of screws to hold the LCD glued. With use or heat (pocket, hand ...) then it starts to come off.
I like that we gather our efforts to file a complaint against Sony because it is shameful what continues to operate in the smartphone sector
-GT
3 REPLIES 3
Masje
My z3 compact has the same problem since 1 week ago. On two parts of the screen it doesn't react.
@Grissa
I'm sorry to hear about your issue but that has been the standard with Xperias for a while now, I still haven't experienced this, you should get in contact with your Local support to get it inspected and repaired.
